Removing unwanted frequencies from circuit and adjusting voltage range of oscillations
Discussion in 'General Electronics Chat' started by artmaster547, Jan 6, 2016.
  1. artmaster547
    Jan 6, 2016
    89
    Hi
    I wish to create a circuit topology that will remove all unwanted frequencies from an input signal, which is created from a phase shift oscillator (if this is possible by implementing something to the oscillator that is even better), to reduce unwanted harmonics as much as possible, I would also like to know if there any topologies that mean the oscillations occur between a certain range Vmin and Vmax
    Art
  2. BR-549
    Sep 22, 2013
    2,164
    415
    Look at mems resonators.
  3. crutschow
    Mar 14, 2008
    13,469
    3,356
    What is the frequency?
  4. artmaster547
    Jan 6, 2016
    89
    1 kHz
  5. artmaster547
    Jan 6, 2016
    89
    Hi Thanks for the suggestion but I would like to create it using conventional analogue components that I can simulate using LTSpice
  6. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,678
    1,295
    Based on your other two threads on the same topic, I suggest that you reduce or eliminate the harmonics by improving the quality of the oscillator. This will be easier than creating a multi-pole bandpass filter or resonant trap.
    ak
