You mean there are actually cases out there of people that succeed at something without crossing their fingers???It is amazing how often crossed fingers are a vital part of success in the lab yet not required once a product goes into production.
Here's what Daumen drücken looks like...I have high hopes and am Daumen drücken.
John
Me too... maybe I didn't cross my fingers right... or pressed my thumbs correctly... or the other way around...I am disappointed. John
Yeah, the lack of a sharp odor is the first thing I noticed about the sample... it's a little nutty, if I could describe it in a word... Gonna follow your advice, thanksAlso, take an old painted surface, the more old coats the better. Add a drop and let sit for several hours. It should remove the paint. NMP has a distinctive, but mild odor. It is not at all sharp and penetrating like methylene chloride.
John
I forgot to mention that another characteristic is that it is a very thin fluid, with very low viscosityThat is a pretty good description of the smell.
John
Thanks for the follow up, John. Yes, there are several suppliers of services relating to metallurgical analysis in the area, and among the range of services that they offer is x-rays (even gamma rays and other more advanced stuff). I'm having the part tested this week, and see how it goes. I've asked them to take x-ray video of it and not just stills so as to get a feeling on how it's constructed. On the other hand, I'm sending another part to a workshop where they're going to mill it in half, so I can see a cross section of it.Acid digestion, sometimes called chemical ashing, is one of the more vigorous methods mentioned. Also, molten NaOH + NaNO3 will probably work. Unless your item is very small, I don't think you want to use either method. Moreover, even with those methods, you need to grind away as much epoxy as practical.
You have raised a question whether the potting is really epoxy. Have you tried burning a chip or sliver of the material?
Any luck finding someone to X-ray it?
John
Is HCl the same as muriatic acid?Save that dust.
See if a portion is soluble in water. Check another portion in HCl or battery acid. Check a third portion is NaOH (lye). Save any remainder. There are ceramic and alumina-based potting compounds. If it is one of those, we have been going up the wrong road -- not that we can remove them any more easily.
John
by Duane Benson
by Duane Benson
by Duane Benson
by Aaron Carman
