Removing PCB potting
Discussion in 'General Electronics Chat' started by R!f@@, May 10, 2010.
  1. R!f@@
    Thread Starter AAC Fanatic!
    Apr 2, 2009
    8,787
    771
    See the attach.
    To remove the potting,. should I boil it or microwave.
    The potting can be chipped off with iron
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Acetone works pretty well, if you don't mind the fire and explosion hazard.
  3. R!f@@
    Apr 2, 2009
    8,787
    771
    acetone.? would it melt the potting.
    If it explodes then I might have a little trouble explaining myself to the cops u know.
  4. retched
    Dec 5, 2009
    5,201
    313
    If it explodes, the cops may have a little trouble finding ALL of you. ;)
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Seriously, acetone will remove a lot of stuff. It's not too good an idea to leave the PCB soaking for too long, though, as it will remove the paint from resistors and the epoxy from the FR4. Your PCB gets a bit floppy.
  6. retched
    Dec 5, 2009
    5,201
    313
    You can then soak it in 2 parts water and 1 part Viagra. Stiffens that puppy right on up. Just take it to the hospital if it stays that way for more than 4 hours. ;)
    However, a quite hot, water bath will work. But you MUST dry the dickens out of it before power up. There are many a technique for PCB drying. I find qtips and ather absorbents, time, and a blowdryer on cool or medium, does well. You will want to let it sit for a few days still to let any capilarily wicked water in hidden spaces to dry.
  7. R!f@@
    Apr 2, 2009
    8,787
    771
    I'll give the water bath a try
  8. R!f@@
    Apr 2, 2009
    8,787
    771
    The hot water bath failed :(.
    So next thing close was the microwave.
    Put in their and gave a 10 sec run.....the whole thing exploded. :eek: good thing evry one asleep. I'll be in big trouble if mom found out :D
  9. retched
    Dec 5, 2009
    5,201
    313
    You put it in the microwave?
    oh jeez. ..I dont... never mind.
    slap your head a few times for me, would ya riffa?
  10. R!f@@
    Apr 2, 2009
    8,787
    771
    Kekekeke. hey there is always a first time. A word of
    Caution... never microwave semiconductors. Bad Idea
    But it paid off, I found the fault. Besides the exploded IC's and caps :D
    I found a scorched and a crispy transistor inside. Now that I know wasn't the result of microwave.
    That PWM driver was toast already.
    Oh by the way it's a cheap tread mill 200V DC motor driver. Just one analog control was there beside the safety switch.
    Now I need to build a new driver for it.
    Any leads anyone? :)
  11. retched
    Dec 5, 2009
    5,201
    313
    Check the top of the inside of your microwave for impaling via silicone. ;)
  12. R!f@@
    Apr 2, 2009
    8,787
    771
    Naa.. microwave is still intact.. I have to check..any problem and mom wud kill me.
  13. retched
    Dec 5, 2009
    5,201
    313
    Then you will REALLY be a legend. ;)
  14. R!f@@
    Apr 2, 2009
    8,787
    771
    why shud I need be dead....I am trying to change the trend.
    I want to be alive to be a legend.
    Hey by the way. have you checked that shipping charge I requested.
    You never replied or did you?
  15. retched
    Dec 5, 2009
    5,201
    313
    Yes. I replied. Are you talking about the glue or the supplements.
    And I meant your mother would kill you, then you would be a legend.
    1 pound or less to you is $11.46 for shipping.
  16. R!f@@
    Apr 2, 2009
    8,787
    771
    OKI DOKI....
    I really am strange, aren't I? :D
  17. retched
    Dec 5, 2009
    5,201
    313
    Yes. yes you are.
    Who else microwaves ICs?
  18. R!f@@
    Apr 2, 2009
    8,787
    771
    no one I guess, well. I guess that makes one and only :D
