Can anyone give me tips on removing surface mount capacitors, without lifting the traces off the board? And when it's time to put them back, what's the best way to melt the solder?
I'm attempting to fix a dead APC RS1500 UPS and I've discovered that a bunch of the surface mount capacitors are dead, but they're a bugger to get off. Using the iron, I can only heat the edges and the traces underneath are lifting off. Using hot air, the cap gets blazing hot (320C) and as best I can tell the traces are still coming up. Is there a secret to it? This has to be one of the most delicate boards I've played with, it's like operating on wet paper towels.
Also when it's time to put these things back, will it kill them to be in 320C air long enough to melt all the solder? Or should I just tack the sides with my iron?
