Remotely open or close motorised front gate via sms (convert constant +12V to single pulse)
Discussion in 'The Projects Forum' started by Custom Trading, May 27, 2016.
  1. Custom Trading
    May 27, 2016
    • Open or close my front gate via a text message.
      Unless there is a better way, the main project (and my biggest issue) is to convert a constant +12V to a single pulse that activates a remote control.
      I have the Unimax HSPA+ Ethernet Modem Router with I/O Board
      The modem/router is already to turn on (+12V) one of the outputs when I send a text (Gate On). Sending another txt (Gate off) will turn off the output.
      I need to use the +12V output to activate the remote that opens/closes the front gate. I assume this will involve converting the +12V output to a single pulse.
      The remote I use to open & close the gate is a Magic Button MBTX4,172,Magic_Button,MBTX4,MBTX4
      I imagine the process working something like this –
      To open the front gate from the closed position
      Send txt (Gate On) – Applies +12V to the output of the I/O Board.
      Convert +12V to a pulse to activate button 1 or 2 (both buttons are programmed to open or close the gate) on the remote to open or close the front gate.
      Send txt (Gate Off) – Turns off +12V output on the I/O Board.
      The same process will need to be followed to close the front gate again.
      How do I do this? Who can build it? What will it cost?
