Remote firework launcher
Discussion in 'The Projects Forum' started by eXodus31337, Feb 18, 2012.
  1. eXodus31337
    Feb 18, 2012
    I want to create a remote firework launcher. I'm placing electric matches on the fireworks's fuses. Then I would like to be able to launch all these fireworks sequentially, at the press of one button. One press, one bottle rocket gone, one press, next one is gone, etc.
    Now, I'm not an electronic guy as much as a programmer. I came up with a schematics, but it's not complete. Could you help me with your expertise?
    Here's the plan:
    1, An easy one for non-beginners would be to connect the LED showing if the circuit is live or not.
    2, My main concern though, is the "automatic switch" in the middle. Does such a device exist that would automatically switch its output destination? Before or after electrical input, it doesn't matter as long as the next output is at a different destination.
    PS: I saw another post similar to this where you guys had safety concerns. Know that I plan to use an advanced 2.4ghz Rx/Tx designed to avoid interference and will shoot bottle rockets with it. I'm not launching missiles with a garage remote :)
  2. Sparky49
    Jul 16, 2011
    835
    417
    To get the LED to light when the circuit is 'live', simply put in series with the switch, with a resistor.
    To get the switching effect, try using a microcontroller. There are some fairly basic languages out there and a few boards which are almost plug and play.
    Perhaps Arduino.
    You set it up so that on the first input signal, it turns on output X, then on the second input signal it turns on output Y, and so on...
    eXodus31337 likes this.
  3. eXodus31337
    Feb 18, 2012
    I'm looking at tutorials right now, they seem pretty easy to use. I'll move the safety switch to include the board too. That'll save power.
    Thanks for the tip!
  4. Sparky49
    Jul 16, 2011
    835
    417
    No problem. I'm glad I could help. :)
  5. Pencil
    Dec 8, 2009
    271
    38
    For a non-microcontroller solution look into
    a 4017 decade counter. It should do what
    you want (with associated circuitry of course).
    Sparky49 likes this.
  6. Bernard
    Aug 7, 2008
    4,248
    423
    To fill in asociated circuitry, need to know elec match firing requirements, two of three, current voltage or resistance? Is the receiver rated for surface use? Output most likley pulsed DC, which can be integrated to give a single pos pulse to step sequencer. Do you have an O-scope?
  7. luvv
    Member
    May 26, 2011
    186
    31
  8. Bernard
    Aug 7, 2008
    4,248
    423
    Something to throw darts at: but must run for now- company at door.
