Remote controlled miniature 3 frequencies generator
Discussion in 'The Projects Forum' started by Nikstor123, Feb 4, 2013.
Thread Status:
Not open for further replies.
  1. Nikstor123
    Feb 4, 2013
    I am taking an electronics design class and we have a product-development project that is described below. I am trying to figure out how to go about it. The tricky part is the size of it. The frequency generation part has to be able to fit in about a matchbox and I have to spec out the parts required to built it.
    Basically I need to be able to generate 3 different frequencies that are 5Vpp with 0.01-0.03mA. All 3 frequencies need to be independent of each other, meaning each one can be turned on/off irrelevant of the state of the others.
    Example, all can run at the same time, or just 2 can run at the same time or any combination, etc. The circuit needs to be able to fit in a matchbox, be able to run for 60 mins and can be controlled in a very simple way from a remote control. I think the remote can be made to have simply 3 buttons , one for each frequency, where each button turns each frequency on or off.
    Attached is also a small conceptual diagram that I came up with... Of course there might be other and more efficient or simple ways to do this ...Please advice! What is the simplest and smallest way built this? I will need to built a functional prototype of this by the end of the month.
    Any input and help will be appreciated!
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    Which sinewave oscillator circuit have you decided to use?
    Have you found a wireless remote?
  3. Nikstor123
    Feb 4, 2013
    At the moment I have no idea as to how to approach any of the design, that's why I am on here to help me gather research or aim me in the right direction.
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
Thread Status:
