Remote controlled dimmer
Discussion in 'The Projects Forum' started by Tackleberry, Feb 17, 2011.
  1. Tackleberry
    Feb 15, 2011
    Hi all
    I am trying to build a remote controlled light dimmer the power source i need to use is a 12v DC battery and the light is a 18 red LEDs 1.2w i have 2 non latching receivers that have a negative output when activated so looking to build a circuit that the receivers will control that will dim the light from completely off to fully bright in about 20 presses of the remote and then work it back the other way with the second button of the remote i built one that was controlled with a pot-meter and a motor but it was a bit to noisy with all the gearing it needs to be super quiet thanks guys any help will be grate
