Remote control of DC motor
Discussion in 'General Electronics Chat' started by xxxyyyba, Jan 23, 2016.
  1. xxxyyyba
    Aug 7, 2012
    249
    Here is schematic that provides polarity inversion and switch off motor if it reaches one of its two end positions:
    SW1 is On-Off-On DPDT switch with the center position Off. SW 2 and SW 3 are limit switches. Motor voltage and amperage are 12V and 2A (max.). Is it possible to control motor remotely, instead of manual control using SW1? If yes, can you provide me schematic? Thanks in advance
  2. Lestraveled
    May 19, 2014
    1,957
    1,217
    What kind of remote control?? Wireless? Wired?
  3. xxxyyyba
    Aug 7, 2012
    249
    Wireless, of course :)
    I need simplest solution. It's not neccessary to be remote control using RF, it can be using IR.
  4. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Also a diode rectifier can be placed across each L.S. and then only two conductors out to the motor side.;)
    Max.
    xxxyyyba likes this.
  5. Lestraveled
    May 19, 2014
    1,957
    1,217
  6. Mr.Meter
    Jan 24, 2016
    7
    Wired - Replace SPDT switch with SPDT relay
    Wireless - I would recommend Xbee S1. Cheap and Easy to use assuming you have some electronics backround.
  7. xxxyyyba
    Aug 7, 2012
    249
    Can you explain it please? :)
    Lestraveled, Mr.Meter
    I would rather build than buy whole circuit :)
  8. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Two conductors out to the motor with each FWD & REV N.C. L.S. all in series, wire a rectifier across each N.C. switch which when the switch is opened, it will be forward biased/allow for the opposite direction/polarity.
    I can post if still needed.
    Max.
  9. xxxyyyba
    Aug 7, 2012
    249
    Something like this?
  10. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Correct!
    Max.
  11. Wendy
    Mar 24, 2008
    20,772
    2,540
    A simpler way is a fast power diode backwards across the motor, like you would use on a relay.
  12. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    How is that going to work with a reversing supply?
    The BEMF is nothing like in a relay or solenoid.
    Max.
  13. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
  14. Wendy
    Mar 24, 2008
    20,772
    2,540
    My bad, brain fart in progress.
