remote control extension
Discussion in 'The Projects Forum' started by peterLuke, Nov 7, 2013.
  1. peterLuke
    Nov 7, 2013
    I've a Elmo Pan/Tilt camera in one room and need to control it with the infrared remote from another room, if I put a infrared receiver in in front of the remote and feed the signal into a Arduino then I can re-transmit the command (through a wire) to an infrared LED in front of the camera, my question is how do I decode the command and re-transmit it.
    Cheers!
  2. tshuck
    Oct 18, 2012
    3,531
    675
    If it's just a pass through, you don't need to decode it...
    However, since you are trying to control it from another room, IR doesn't seem like a good option...
  3. mcgyvr
    Oct 15, 2009
    4,789
    975
  4. peterLuke
    Nov 7, 2013
    Thanks for the link, it's exactly what I'm looking for.
  5. ErnieM
    Apr 24, 2011
    7,436
    1,626
    Good lord, people actually use a micro for this?
    Take a plain 38KHz IR receiver and use it's output to gate on and off a '555. Set the 555's RC for a to nearly square wave at 38KHz. Drive an IR LED with that.
    And just make sure the receiver can't see the emitter.
  6. mcgyvr
    Oct 15, 2009
    4,789
    975
