You should have gone through the wire wrap era!I maybe opening up a can of worms here Also Crown used to use a crimped mechanical connection on there pcb because they claimed the crimp was better then a soldered connection? .
Max.
Flexing any board can cause problems; and not just for solder joints. Unless a board is designed to be flexed, it shouldn't be stressed in that manner.I am sceptical of the claim that SMT is more reliable as if you flex the board you can crack the the solder joints on the boards
It's unlikely that it was due to heat. The temperatures required to make parts fall off would be the same required for soldering; around 600-800F.sometimes when you open up electronics you find components rolling around the case because they got hot then fell off the board.
Soldered joints shouldn't be used for their mechanical strength.Also Crown used to use a crimped mechanical connection on there pcb because they claimed the crimp was better then a soldered connection?
Thru hole is better for reliability due to the mechanical advantages, but you need to look at the whole system. For example if you have to use 2 boards instead of one. Then you need to factor in contact reliability.Well I agree that a pcb should not get stressed, however I still have seen my fair share of warped and permanently deformed circuit boards?
Yes I have worked on several pieces where the components will heat up and fall from the pcb, it is enough to boil the solder of the other surrounding components as well. The problem of what would cause the component to heat up is lease of my concern here, I guess where I am going with that is it is much more unlikely for a thru hole component to fall off roll around and ruin other stages or pieces of the circuit?
If you need to get signals from one board to another you will need tome kind of connector. They can have poor reliability.Not 100% clear on your example? Are you saying if the 2 boards are stacked on top of one another or connected with pins?
Funny you bring the pin and header up. I had a problem once with 3 boards stacked using pin and header. It worked really good but one cap would always go bad - not a lot of failures, but enough to know something was wrong. Turned out to be internal fracture due to pressing the boards together.You know I didn't give your comment much thought at first but now it seems obvious, Connectors are the most likely things to have problems in electronics. So I guess my interconnection might be a bigger issue then if I chose to use SMT or thru hole. I have given much thought to audio connectors but not to connections from pcb to pcb??? I usually stick with pin and headers, because it's all I am use to using. However I will follow this down the rabbit hole and see what is the latest and greatest. I do like the idea of soldered connection but that might not work so well on equipment that I am constantly changing or experimenting with. Wire wrapping?!?
