reliability function and failure rate
Discussion in 'Math' started by vead, Jul 21, 2014.
  1. vead
    Nov 24, 2011
    621
    8
    reliability means the probability of device that device will perform for given time interval under given condition
    or
    probability of device that will fail during certain level of time
    what is use of reliability function ?
    failure occur when device stop working
    failure rate probability of device that the device will fail per unite of time
    what is mean time to failure and mean time between failure ?
  2. tshuck
    Oct 18, 2012
    3,531
    675
    These are used to estimate how long a device will operate before requiring repair. The more often a device needs to be repaired, the higher the overall cost of a product.
    Failure rate could also refer to the normalized failure rate of components within a device, as compared to the overall failure rate of the device on the whole. This failure rate would be useful in determining the most probably cause of failure in hopes of reducing repair time.
    Another number related to these is the mean time between failure (MTBF), which is the average amount of time the device will operate properly.
  3. vead
    Nov 24, 2011
    621
    8
    can you tell me what is difference between stochastic process and Markov process. both are same are different
  4. wayneh
    Sep 9, 2010
    12,374
    3,226
    The latter is a subset of the former. See here.
