Hi, Im attempting to make an led cube with arduino. Since there is multiple layers of the cube that act as the ground, I need a way to switch between multiple grounds. I was thinking of attaching each layer to a different latch relay that is controlled by a separate pins that will give the relay voltage thus allowing the circuit to complete and light the led on the specified layer. My question is whether or not a latch relay is the correct part I would want to use for this? would this be the easiest/most-simple way doing this or am I misusing latch relays? Forgive my little knowledge of circuits, im mostly a software guy that is just discovering the complexity of electronics.
