I use HFD27/005-S relay dpdt device that work with 5 volt and minimum 40 mili amper
I want to turn on this relay with PIC18F the leg of the relay need to receive 5 volt for "1" logy
The problem is that the PIC can out maximum 25 mili amper and this is give that "1" logy is 3 volt and not 5 volt
I search after solution for this problem
