Relay
Discussion in 'Homework Help' started by Cerkit, Jun 1, 2009.
  1. Cerkit
    Thread Starter Active Member
    Jan 4, 2009
    275
    How is it that the magnetism from the coil in a relay switch does not distort the signal passing through it?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The coil and the contacts are somewhat separated, and the signals through the contacts do not have any relationship to the energizing current in the coil.
    Passing a signal in the vicinity of an magnetic field has no effect on the signal, as the magnetic field is concentrated by the pole piece.
    http://en.wikipedia.org/wiki/Relay
  3. mik3
    Feb 4, 2008
    4,846
    63
    Relays operating with a DC coil don't affect the signal because the magnetic field does not vary with time. The only time it can create noise in the signal is when it switches on/off.
    Relays operating with AC can add noise to the signal conducted by the relay. However, relays are designed in such a way that the magnetic field is weak in the vicinity of the relay conducts. Also, the length of the conducts is short and thus the induced voltage will be tiny.
