Relay wiring- microcontroller- is this correct??
Discussion in 'Embedded Systems and Microcontrollers' started by petty54, Oct 10, 2009.
  1. petty54
    Oct 10, 2009
    I am current working on a relay circuit for my basic stamp microcontroller which will drive a 24V DC motor (I measured 1A-2A) forward or reverse. A limit switch is built into the motor and not shown on the schematic.
    My circuit is for a 24V application and I am using two 12V lawnmower batteries. I thought about also adding 3A fuses on both sides of the transistors.
    Is this the best/ simplest approach? Should I add the fuses? Should I use a separate battery to operate the relay? I there anything else I need to add to prevent damage to the microcontroller?
    Please see attached pdf file with the schematic and componet specs.
    I am new to microcontrollers (basic stamp) and any comments or suggestions are appreciated.
    thank you.
