Relay Teaser Question
Discussion in 'General Electronics Chat' started by saint_jay77, Aug 23, 2007.
  1. saint_jay77
    Oct 19, 2006
    26
    SIMPLE SOLUTION REQUIRED
    I have to find a way to check to make sure the 2 relays in the circuit which are connected in series work switch. I do not want to use any other source of power but 48V.
    Is there a way using hardware the circuit can be tested.
    Failure modes to consider are typically the relays getting stuck on contacts and not switching off. Meaning relays are stuck to the pole.
    Is there a way to detect this???
  2. nanovate
    Distinguished Member
    May 7, 2007
    665
    Can you post a schematic? You might be able to use an optocoupler to feedback a signal to the control electronics.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If the contacts conduct current when active, then looking for continued current when the relay is supposed to be inactive will let you see if the contacts actually open up. You can also check for voltage across the contacts. If the voltage is zero, then the contacts are stuck.
  4. techroomt
    May 19, 2004
    198
    you may want to look at something called force guided relays.
  5. nanovate
    May 7, 2007
    665
    Do you need to check this from the "coil" side or can you check it from the contact side? In other owrds do you need to maintain isolation?
