Relay system
Discussion in 'The Projects Forum' started by raj varshney, Apr 27, 2013.
  1. raj varshney
    Apr 27, 2013
    Hi.... I want to make project in which i have put a circuit through which i can change the power source from one to another without switching off the circuit or it should remain on while changing the power source.... :confused:
    Thanx for the help. :)
  2. parttimegeek
    Apr 27, 2013
    I have given this thought a few times myself, but haven't taken the time to do any research on it. My thoughts have been to use properly sized capacitor(s) to keep the current flowing while the relay switches (as my case would be). I'm thinking with the properly sized caps it should work... but have no practical experience doing so and will be watching for others ideas. Are you planning on using a relay or how exactly are you planning on changing power supplies... like from battery power to a power supply or as in moving from room to room?
    raj varshney likes this.
  3. parttimegeek
    Apr 27, 2013
    Just realized your title says "Relay system"... nevermind the question of how you plan to change power sources.
  4. tracecom
    Apr 16, 2010
    3,878
    1,396
    Google "make before break relay" and see if that helps at all.
  5. ScottWang
    Aug 23, 2012
    4,925
    777
    What are the two power sources come from?
    If the two power sources are DC then how about the V,I?
    How is the V,I of the circuit?
    If the whole units are dc, then it could be done for this are using relay, bjt, mosfet, do you only want to do with relay?
    Do you have any ideas how to complete your project?
  6. raj varshney
    Apr 27, 2013
    @scott My both power sources are DC with equivalently V & I and V= 6v, I= 0.9 amp
    I wanted it to be cheap so what should i take ? my ideas were to put upon capacitors with two manual switch and a diode .........
    Thanks a millions for all those who helped.. :)
  7. ScottWang
    Aug 23, 2012
    4,925
    777
    You can check the circuit as below or change it by yourself:
    SPDT Switch.
    You can choosing rectifier diode rating 2A or more.
    2A Rectifier diode.
  8. raj varshney
    Apr 27, 2013
    @ scott i wanna ask that the "circuit" label in circuit u provide is my output right? or.......
    Do i need any capacitor or resistors.....
    Thanks a billion :) :D
  9. ScottWang
    Aug 23, 2012
    4,925
    777
    The circuit label shown that it is your circuit, and the two power sources will be output the current through the +V to your circuit.
    You can adding a 220uf/25V capacitor in parallel with the +V of your circuit.
  10. raj varshney
    Apr 27, 2013
    hello again, which is the +V in my circuit..... also,
    hey can do something as do have 1000uf/16V capacitor *5. can i do something.........
    Thanks a trillion...... :) :D
  11. ScottWang
    Aug 23, 2012
    4,925
    777
    The +V is that where is the power input of your circuit.
    If you want to using 1000uf/16V *5 to replace 220uf/25V, normally is ok for that, but because I didn't know anything about your circuit, so it maybe something that I don't know and it could be happended.
    Why you want to using the capacitor so large(1000uf/16V *5)?
