Now, I've already got numerous problems with my design. I didn't do the math and instead used the Java Circuit Simulator applet to complete the design. This of course resulted in a 5V input which I'm gonna have to figure out how to do. Should've probably used something smaller but as a result I've already purchased two relay switches with a 5V, 1A input for the coil.
Secondly I bought 4 2V LEDs and 10 10Ohm resistors.
Now I'll deal with the math and buy the extra components if I need to after I re-do the design but what bothers me is the little diagram beneath the Relay Switches that I got. They're 8-pin switches which immediately made me think that there are two switches contained with the the Relay itself. I'm probably just not going to use the second switch if it can't be switched seperately, which is fine for now. I'll replace the component later with the correct one. But what really confuses me is the bellow diagram on the switch. It just doesn't fit with the picture that I have of how a switch works in my mind.
The first two connectors (NOT shown) are clearly for the coil but I don't understand how the above becomes switches.
Doesn't anyone have an idea?
