Relay Switch Question
Discussion in 'Homework Help' started by dotnetforce, Feb 24, 2009.
  1. dotnetforce
    Feb 24, 2009
    Hello All,
    I have a quick question.
    This is the requirement.
    I need to control a low voltage circuit (5 Volts), with a 120 Volt input.
    If the 120V circuit is closed, then it needs to close the 5V circuit too.
    Do I do it with the relay ?
    I have attached the picture along with to make my question clear.
    The incoming 120V, should control the 5V circuit.
    Any suggestions or ideas guys ?
    Awaiting your valued responses.
    thanks
    Shawn
  2. jut
    Aug 25, 2007
    224
    Do you mean you need to control a 120V circuit with a low voltage circuit?
  3. dotnetforce
    Feb 24, 2009
    Hello Jut,
    It is the reverse.
    I need to control 5V circuit with 120V.
    If 120V is ON, then it should put on the 5V circuit.
  4. LesterPhil
    Member
    Feb 25, 2009
    10
    aaaa..... why should you use a relay..... it makes no sense... how about using a step down transformer with a simple circuit bridge,capacitor,and 7805 regulator.....
    if you will going to plug your 120vac the bulb will light-up....
    okok....
  5. dotnetforce
    Feb 24, 2009
    Hello LesterPhil,
    Thanks for the reply.
    I am not an electronics guy :(. I learnt electronics in school and that was it.
    I am working on a project at work and I have this need and need to come up with a circuit.
    I would really appreciate a ton if you can give me the circuit diagram for the above described solution.
    Also, the solution should make sure, the 120V circuit does not burn the 5V circuit ( Do we use a fuse or something like that ?).
    It needs to be a very robust circuit.
    Appreciate the help man.
