relay simulator
mannycc
Joined Dec 11, 2010
17
Hi guys,
I've been searching for a free software for the relay simulator (or sometimes called ladder) on the web without success. The reason should be obvious, i'm working on the combinational circuit using relays and so appreciate information from you...
Thanks.
mannycc
Joined Dec 11, 2010
17
OK guys,
Finally fond something from web, it is Logixpro PLC trial version but I have to admit that this is too advance for me... looking for something where you can cut/paste/run functions... without going to all the complexities.
Thanks.
panic mode
Joined Oct 10, 2011
2,754
try Zelio software, it is free, supports ladder and function block and have simulator. you can also get one of controllers, they are low cost and easy to use.
