Relay question
Discussion in 'General Electronics Chat' started by twist2b, Mar 27, 2009.
  1. twist2b
    Jan 12, 2009
    10
    I am doing a touch controlled switch that uses Flip-Flop and relay, pretty classic.
    Though, it does not specify and good relays, just get a 12V one.
    http://www.alliedelec.com/Search/Pr...R=8862250&SEARCH=8862250&DESC=V23105A5003A201
    This is the one I am looking at, but the data sheet SUCKS! It does not just show the insides... what the pins control. SO Yeah, I need a place to start and wondering:
    1. How to wire up this thing
    2. How it works exactly, I know it works via logic, but what are the 3 leads for it, I want to turn on ALL my circuit board (this is just an addon) Is it 2 to 1 or 1 to 2?
    ANyways, let me know.
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Actually the datasheet is not that bad. There is a diagram that shows a basic diagram of the inside functions.
    hgmjr
  3. twist2b
    Jan 12, 2009
    10
  4. BillB3857
    Feb 28, 2009
    2,402
    348
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    Check out the diagram labeled "terminal assignments" at the bottom of page 4 of 12.
    hgmjr
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The diagram is on the bottom of the 2nd page (labeled 4 of 12), under "Terminal Assignment".
  7. hgmjr
    Jan 28, 2005
    9,030
    214
    For example the coil is connected to pins 1 and 16.
    hgmjr
  8. twist2b
    Jan 12, 2009
    10
    Oh ok holds on....
    edit - so it does not show all of the pins, and teh main functions of ALL of them -_-
    Maybe its just me, but I prefer a full explanation for all pins and what I can do with the chip.
  9. twist2b
    Jan 12, 2009
    10
    Just to make a new post, this is my guess:
    http://www.electronics-project-design.com/free-electronic-circuits.html
    12v to 1k resistor to pin 16 and then one just goes on.
    I am guessing 11 13 pair is open while 4 6 pair is closed.... vise-versa.
    9 is high when 11 13 pair is closed
    8 is high when 4 6 pair is closed
    it could be that the 2 pairs close at the same time but 9 or 8 is not-ed.
    I would just have to test it......
    Good guess?
    i still dont like it -_-
    edit - OH OH OH!!!!
    i zoomed in :p
    i see that I would use 4-6-8 or 11-13-9
    and it switches between 6-8 or 11-9
    Haha, my bad.
