I don't have a high end meter, so I am sure you are right. I did hook up some talons and ematches tonight and tried to get current readings, but I still was not seeing anything over 400mA. I could see with multiples hooked up it could get up into amps.The test current is limited by an internal resistor at around 55 mA. Your meter probably is not catching the transient firing current. Scott says it is amps, not mA, for a brief period.
ak
by Aaron Carman
by Jake Hertz
by Jake Hertz
by Jake Hertz
