Relay or Timer??
Discussion in 'The Projects Forum' started by Nobill, Nov 5, 2008.
  1. Nobill
    Nov 5, 2008
    I got a small motor, like one out of a remote control car. It runs off of a 6 volt battery. When you turn the switch on, it comes on and stays on (like it is suppose to do). But, I want to put a relay or timer in it that would make it run for 15 seconds and then shut off for 5 seconds. Then when the 5 seconds is up, it will come back on for another 15 seconds. How can I accomplish this and would it be expensive???
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Nope, a 555 timer with a transistor would work just fine. If someone doesn't beat me to it I'll put up a schematic later.
    Vcc = 6V, t1 = 15 sec, t2 = 5 sec, C = 10µF, Diode = 1N4001,
    Ra = 750 KΩ (721.5 KΩ), Rb = 1.5 MΩ (1.415 MΩ)
