Relay or NPN Transistor? and One or 2 Power Sources?
Discussion in 'The Projects Forum' started by Clexxy, Jul 12, 2014.
  1. Clexxy
    Jul 12, 2014
    In the attached JPG, I can't figure out how, once LED C, D, or E switch is closed (via reed-switch) then how to also activate the circuit that has LED-G and the speaker. I may only use one power source, but the circuit that has the LED-G and Speaker should not go above 12 volts total (9 for alarm and 3 for the LED). Otherwise, until one of those additional switches are activated, the usual power will be going through LED-A, and B when the system is activated and at normal status. Thanks for any help or criticism!
  2. Dodgydave
    Jun 22, 2012
    5,167
    777
    Use three diodes from C,D,E to G, or one diode from F to G.
  3. eetech00
    Jun 8, 2013
    685
    118
    Hi
    This should do it...
    eT:)
