Relay or electronic switch
Discussion in 'General Electronics Chat' started by andrewwallaceuk, Mar 10, 2016.
  1. andrewwallaceuk
    Oct 20, 2015
    Hi Guys,
    Complete newbie here so apologies for my ignorance in advance.
    I have a project on the go at the minute and I'm a bit stuck. Basically I have a control board which operates a relay. I want this relay to operate a mechanical actuator. The problem is I need a neutral position with the actuator otherwise it is going to burn the motor out. At the moment I only have normally open or normally closed positions which I use to drive the actuator in one direction or another.
    Is there such a thing as a three position relay in which I can have one position with no current flowing?
    Thank you for your time in advance.
    Andy
  2. tracecom
    Apr 16, 2010
    3,879
    1,396
    A K-form relay has a center off position.
  3. andrewwallaceuk
    Oct 20, 2015
    Will I be able to toggle between two other positions?
  4. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,699
    1,298
    It sounds like the relay performs the reversing function, probably with DPDT (double-pole, double-throw) contacts. If so, a common solution is two SPDT relays controlled by a center-off switch.
    ak
  5. bwilliams60
    Nov 18, 2012
    734
    94
    Would something like this solve your problem?
  6. Dodgydave
    Jun 22, 2012
    5,155
    772
    Yes, two separate relays, so one is driving the motor one way, no relays activated no movement.
  7. tracecom
    Apr 16, 2010
    3,879
    1,396
    The OP said that the relay was to control a "mechanical actuator." I take that to mean that the motor direction is controlled by the position of this mechanical actuator and that the actuator makes and breaks the electrical connections to the motor to control its direction.
  8. alfacliff
    Dec 13, 2013
    2,449
    428
    a reversing relay usually has a mechanical linkage to prevent both sides from energising at the same time, which woud be bad.
  9. MrSoftware
    Oct 29, 2013
    545
    133
    A couple of relays, or an H-bridge. Or you could use limit switches to stop the motor when the actuator reaches its end points. Combine with a fuse of some sort in case it gets stuck somewhere in between.
