Relay Needed, What Type?
Discussion in 'The Projects Forum' started by DanishC, Mar 18, 2009.
  1. DanishC
    Mar 18, 2009
    Hi Guys
    I'm working on a little project for my car. I have 4 CCFL tubes along with a transformer to accept the 12vdc from my car.
    I want the tubes to accept two separate positive sources, one from the headlights (so they turn on when the headlights are on) and two from the map light so they turn on when the doors open.
    Since I'm using two electrical sources I understand I'll need a relay. How many will I need, what type, where will they connect and is there anything else I'll need for this project?
    Thanks a bunch
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    What is the current draw of the EL tubes? It is possible that this could be accomplished without relays.
  3. KMoffett
    Dec 19, 2007
    2,584
    234
    Like an OR'ing circuit with 2 diodes?
    Diode 1's anode to headlight circuit.
    Diode 2's anode to map light circuit.
    Diode 1's and 2's cathodes tied together and to CCFL's driver (+).
    CCFL's driver (-) to ground.
    Ken
  4. DanishC
    Mar 18, 2009
    Each cathode transformer draws about 0.7 amps of power at 12 volts.
  5. KMoffett
    Dec 19, 2007
    2,584
    234
    This is what I was thinking about.
    Ken
  6. thatoneguy
    Feb 19, 2009
    6,357
    718
    That's what I had in mind. :)
    Load of 0.7A should be OK with your schematic as well.
