Hi everyone,
I have two relays controlling two independent parts of the circuit. And both coils are in parallel with a 5V generator (sufficient for this relay).
But what i can't understand is that one relay switch from NC to NO and works fine while the other isn't neither in NC nor in NO! I've tested them and they are ok, the problem happens when they connected together.
Is it something common to happen? Where should i start looking for a solution?
Thank you !
Thank you !
