Relay Help
Discussion in 'The Projects Forum' started by Graham Engley, Mar 17, 2016.
  1. Graham Engley
    Mar 17, 2016
    5
    Im new to electronics and I want to use a couple of latching relays.
    I have this relay, but unsure how to wire this up to latch a motor.
    https://www.schukat.com/schukat/sch...11&refDoc=CMSDAD9057DF9FBACE3C125708A004D3703
    This is my circuit, basicly when a door is opened the motor turns forward, gets to a point and hits a switch and then stops and a light turns on.
    When the door is closed the motor turns backwards and the light turns off and gets to a point and the stops.
  2. Graham Engley
    Mar 17, 2016
    5
    I have made the circuit on breadboard.
    The open door switch starts the relay which turns the motor forward and hits the light switch and turns the light on and the motor stops. (Okay here)
    The door switch is then closed which starts the relay which turns the motor backwards and the laser goes off but is being dragged down and parts get very hot!.
  3. Dodgydave
    Jun 22, 2012
    5,159
    772
    With your circuit, the relay only works when going one way, so you must have wired it up wrong.
  4. Graham Engley
    Mar 17, 2016
    5
    It goes both ways,
    How do I wire the relay up, ive added a link for?
  5. Dodgydave
    Jun 22, 2012
    5,159
    772
    Your relay is just a normal single coil type, there is a diagram of its pinout on the link.
