Hello community,
I'm attempting to implement a serial controlled relay driver using a PIC16F877A uC.
My circuit can be described in the next manner: A +12v input, a LM7805 for a net of +5v, a MAX232 for TTL signal conversion, PIC16F877A for serial communication and controlling the output port on which eight relays will be controlled. Each relay will power up a +12v strobe light at a time.
I have the schematic done but I'm struggling with the programming of the PIC, I have read several tutorials on using USART for serial communication an I have the following code:
Any easier way of setting this up?
Thanks, any help will be greatly appreciated.
Let's take a look at the main loop:// PIC16F877A Configuration Bit Settings
#include <xc.h>
// CONFIG0
#pragma config CP = OFF // Code protection OFF
#pragma config DEBUG = OFF // Debugger OFF
#pragma config WRT = OFF // Flash program memory write OFF
#pragma config CPD = OFF // Data EEPROM memory code protection OFF
#pragma config LVP = OFF // Low voltage In-circuit serial programming OFF
#pragma config BODEN = ON // Brown-out reset enable ON
#pragma config PWRTE = OFF // Power-up timer enable OFF
#pragma config WDTE = OFF // Watchdog timer enable OFF
#pragma config FOSC = HS // Oscillator HS : High speed crystal
#define STRLEN 12
volatile unsigned char t;
volatile unsigned char rcindex;
volatile unsigned char rcbuf[STRLEN];
void USART_init(void)
TXSTAbits.TXEN = 1; // enable transmitter
TXSTAbits.BRGH = 1; // high baud rate mode
RCSTAbits.CREN = 1; // enable continous receiving
// configure I/O pins
TRISCbits.TRISC7 = 1; // RX pin is input
TRISCbits.TRISC6 = 1; // TX pin is input (automatically configured)
SPBRG = 25; // set baud rate to 9600 baud (4MHz/(16*baudrate))-1
PIE1bits.RCIE = 1; // enable USART receive interrupt
RCSTAbits.SPEN = 1; // enable USART
void USART_putc(unsigned char c)
while (!TXSTAbits.TRMT); // wait until transmit shift register is empty
TXREG = c; // write character to TXREG and start transmission
void USART_puts(unsigned char *s)
while (*s)
USART_putc(*s); // send character pointed to by s
s++; // increase pointer location to the next character
int main(void)
USART_init();
USART_puts("Initialized!\n");
INTCONbits.PEIE = 1; // enable peripheral interrupts
INTCONbits.GIE = 1; // enable interrupts
TRISD = 0; //Define PORTD as output
while(1)
if (rcbuf == "relay1")
PORTBbits.RB0 =1;
return 0;
void interrupt ISR(void)
if (PIR1bits.RCIF) // check if receive interrupt has fired
t = RCREG; // read received character to buffer
// check if received character is not new line character
// and that maximum string length has not been reached
if ( (t != '\n') && (rcindex < STRLEN) )
rcbuf[rcindex] = t; // append received character to string
rcindex++; // increment string index
else
rcindex = 0; // reset string index
USART_puts(rcbuf); // echo received string
PIR1bits.RCIF = 0; // reset receive interrupt flag
Will this set RB0 to high when the string at rcbuff is relay1?while(1)
PORTBbits.RB0 = 1;
