Relay don't work
Discussion in 'General Electronics Chat' started by hassan maysara, Feb 24, 2013.
  1. hassan maysara
    Oct 23, 2012
    14
    I have made a circuit using Ic 4017 and it worked but when i connect the output (about 4.2v) to 3v relay the relay didn't work so what is the solution????
  2. kubeek
    Sep 20, 2005
    4,689
    806
    You can´t feed an output of a logic IC directly to a relay, you need to use a transistor switch.
  3. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    The 4017 will not be strong enough to drive a relays, as it can only have an output current of about 6 mA.
    You will need a driver to drive the relays.
    Bertus
  4. hassan maysara
    Oct 23, 2012
    14
    sorry for this question because i am beginner :) any kind of transistor will be useful or a specific one ??? please write the number
  5. kubeek
    Sep 20, 2005
    4,689
    806
    first you need to specify the relay, mainly what current does it need to operate.
  6. hassan maysara
    Oct 23, 2012
    14
  7. sheldons
    Oct 26, 2011
    616
    101
    This gives you an idea of the sort of relay driver you can use
  8. hassan maysara
    Oct 23, 2012
    14
    Thanks sheldons... I really appreciate your circuit
  9. panic mode
    Oct 10, 2011
    1,328
    305
    note that relays require certain power to work. in general low coil voltage means large current. depending which of the three 3V relays you have, coil current can be up to 150mA. also note that since transistor is used as switch, gain is lower. in general this means only gain of 10 or so. therefore you will want to reduce R1 value from 3.3K to something smaller because:
    if your 4017 is also powered from 3V and it's output is close to 3V, you will have at best base current of
    Ib= (3V-0.7V)/R1 = 0.8mA
    to get 150mA, you would need gain 150/0.8 = 187.5 which is huge for switching application.
    assuming we get 6mA from 4017 that resistor would need to be
    R=V/I = (3-0.7)/0.006 = 390 Ohm (rounded to common resistor value)
    in this case you still need gain of 25 if your relay coil is 0.45W.
    if the relay coil is 0.2W, you only need gain of 11.
    if you are using standard LED (poor efficiency), you will need R3 of about 33 Ohm.
  10. Jaguarjoe
    Apr 7, 2010
    770
    90
    Be careful, you only have a 3V relay coil. If you apply 12V to it as the example shows, the relay will not last more than a portion of one operation.
