Since this is my first post, I'd just like to introduce myself. My name is Mike, and I am from Grand Rapids, MI. Also, I know next to nothing about electronics, which is why I'm here!
To my question: I have an external HDD that I have hooked to my Nintendo Wii, which I use to play backups of my games. The problem with this is, the drive does not have a switch to turn it on/off, and un/plugging it every time I use it is difficult due to where I have it located. What I'd like to do is make it so that my drive will turn on/off when I turn my Wii on/off. From my limited knowledge, I need to use a relay. The only signal going from the Wii to the drive is the USB cable, which sends a 5v current, and I assume this could be used to trigger the relay. The other pins of the relay could be connected to either the internal molex connector which would just turn the drive itself on/off, or somewhere else powering the entire enclosure. Either way would be fine with me, just as long as the drive doesn't spin when I'm not using it.
So, I guess my question is what type of relay should I use, and what would be the best way to wire it up? Thanks for any help you guys/girls may give me.
