MaxHeadRoom
- Joined Jul 18, 2013
- 28,702
@renegadegas Just out of interest what is the label above the black square item just to the right of the top toroidal transformer?
Max.
Max.
I am referring to what is apparently some pink coloured tape with a legend written on it above the device as if a schematic identifier for e.g.What you see as a label I see as the relief cuts in the top of an electrolytic capacitor.
And in the process, document itBy the look of the state of the panel it is too late, The only hope for the system is to gut it and re-fit!
Max.
Agree 100%.And in the process, document it
Most of the machines I build have no PLC's in them, but are rather controlled by a PC interfaced with a few circuits of my own making, since most of the time the machines are being controlled by simple, discrete inputs and outputs. A PC is extremely easy to back up, and does not require specialized knowledge to do so. And the interface cards are mostly comprised of inexpensive, easy to find chips and components.... And yes, they're always thoroughly documented ..Agree 100%.
Another problem I see here where this machine appears to be of some consequence according to the size and apparent replacement cost, if the PLC caves and a back-up ladder is not on file, the machine reverts to junk, if the OEM cannot supply support and a PLC ladder, then it will be worth the 1/2 days pay for a tech to come in and download the ladder, it takes all of 1/2hr tops.
It is amazing how many people buy CNC machines via an auction etc. and do not have, or download the memory/parameter backups, as soon as the back up battery goes they those everything, and the machine reverts to a chunk of Iron!
Max.
