Relay Coil Rating
Discussion in 'General Electronics Chat' started by vindicate, Aug 5, 2009.
  1. vindicate
    Thread Starter Active Member
    Jul 9, 2009
    158
    I was looking at a 5v coil relay to switch 120VAC. The nominal current was listed as 200mA. So is nominal current the max current it needs? The minimum current it needs? Or what? How does that work? Does it draw what it needs?
    Could I give it 6 or 7 volts but with a resistor inline to limit the current?
  2. KMoffett
    Dec 19, 2007
    2,584
    234
    Can you post a link to that particular relay?
    Ken
  3. vindicate
    Jul 9, 2009
    158
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Just place a diode like a 1N4000 in series to drop the excess - for 7 volts use 2. Relays are not sensitive to overvoltages, but the coil will heat and possibly fail.
  5. mik3
    Feb 4, 2008
    4,846
    63
    Yes, it will draw 200mA.
    You can use a resistor with an appropriate value to limit the current if you drive it with higher voltages.
  6. vindicate
    Jul 9, 2009
    158
    So with the 5v 200mA example I gave I could use a 10v supply and a 25 ohm resistor rated for 1watt?
  7. mik3
    Feb 4, 2008
    4,846
    63
    Yes you can!
  8. vindicate
    Jul 9, 2009
    158
    Excellent. Thanks you.
    Last question. Pull In Voltage. It's listed at 75% or less of nominal voltage. So If I have a 5V coil, could I technically power it with 4V and it would work fine?
  9. mik3
    Feb 4, 2008
    4,846
    63
    Yes you can but it is better to power it with the nominal voltage.
  10. vindicate
    Jul 9, 2009
    158
    Alright, thanks for everything :)
