Relay coil data sheet. Resistance varies with wattage?
Discussion in 'General Electronics Chat' started by Mrdouble, Apr 2, 2016.
  1. Mrdouble
    Aug 13, 2012
    86
    image.jpeg I ordered couple relays off relay and just reading the datasheet. Can someone explain what the coil resistance varies with wattage? Resistance doesn't change of a coil in DC so what am I missing. Maybe I'm interpreting it wrong. I'm interested in the 12 v
    Thanks in advance
    Micheal
  2. #12
    Nov 30, 2010
    16,703
    7,341
    If you bought a 12 volt relay that needs 0.15 watts, it will have a resistance of 960 ohms in the coil.
    ....................................................... 0.2 watts..............................................720.............................
    ....................................................... 0.36 watts............................................400............................
    ....................................................... 0.45 watts.............................................320.............................
  3. Mrdouble
    Aug 13, 2012
    86
    Ahh, so you think different coils within the 12v lineup? That hadn't crossed my mind
  4. Mrdouble
    Aug 13, 2012
    86
    Ok, I'm with you but why would anyone choose anything but the lowest wattage coil?
  5. crutschow
    Mar 14, 2008
    13,501
    3,375
    Perhaps cost or operating speed.
    Mrdouble likes this.
  6. #12
    Nov 30, 2010
    16,703
    7,341
    Maybe a hotter coil wattage can slam bigger contacts together properly.
