I am running a load (6 amps) off a deep cycle battery that has a low voltage sense circuit on it. The problem I am running into is when the battery is going dead around 10.80 volts the relay starts to chatter on and off.
What I am looking for is a way to keep the relay from reengaging when the voltage rises because the load was disconnected.
I have a voltage window detector MC64161, but what I am really looking for is a way to shut off the load to the battery when it go's to something like 11 volts, so I don't over discharge it.
