I'm trying to trouble shoot this amp . No output at all after Led Zep.
Left to cool off (I was sweaty) during which time the amp shoulda too.
Turned on - relay clicks away after playing ok for a few minutes. Does this repeatedly so gets put in garage.
Months and months later nothing from amp at all. Also no schematic from manufacturers of amp or relay. How helpful.
The second picture is flipped for your convenience hopefully.
The relay has 6 pins 2 to speaker outs (white conn. top Left). headphones (from cntre pins) and the lower two pins go to the large smoothings caps via some diodes transistors etc. I measure 31.2v at both of these with respect to chassis ground.
I have been signal tracing using the rather excellent non propriety Rolson 6mm Titanium Injector. At the relay I can hear the headphone tone and the speaker tone.
On power up I hesitantly touched my Rolson to these pins in turn whereupon the relay clicked in on one side only. No audible tone (or programme material in a later test) The Rolson produces a rough 1kHz tone and the signal is at 3.8V (amplitude?)
I'm purely guessing but probably the relay switches between amp output and headphones. Is the extra voltage enough to click in and hold the relay?
Am I barking up the wrong tree?
it may take me ages to draw a schematic so hopefully I can get a prod in the right direction.
