Relay 240V
Discussion in 'General Electronics Chat' started by g-rick, Jun 12, 2007.
  1. g-rick
    Jun 12, 2007
    Is ok to parallel an on/off switch with a 240V relay. The relay already installed is used to control a motor for pumping liquid into a tank. I would like to manually turn the motor on occasionally whenever the relay is not being used.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That should work perfectly well. Just make sure power is off while you wire the switch in.
