Relaxation oscillator Noob need education
theSwede
Joined Jan 26, 2013
Don´t laught please :) need some help about my project what i basically want is a solenoid "electromagnet" That switch its magnetic flux in a Oscillation fashion. Much like a speaker my solenoid is about 1.5 ohm. And to get the oscillation i research about relaxation oscillator and transistor oscillator but i went for the Rel for the of easy build. But i am very noob and i cant get it to work. The pic below show schematic and how i assemble it
Probably i am so noob that my theory is not valid. I want to have the output voltage the same as i take in in order to get stronger or softer magnetic field but i only get 0.04 mv at the output i have an pot to regulate the freq the voltage do increase or decrease in the output some but do not oscillate i think.. i thing i destroyed the ic or i connected it wrong. or it is the wrong circuit all together? hope i have explained my self clear sorry otherwise!
tracecom
Joined Apr 16, 2010
3,944
Assuming that the op-amp is an LM741 or equivalent:
What is the power voltage and source?
The cap looks very big for 1 μF; is that what it is? Do you have the polarity correct?
What is the value of the pot? Try removing it and using the 10k fixed resistor to see if it oscillates.
theSwede
Joined Jan 26, 2013
Hello yes it is a lm741.. and yea i tried switching from a 1 uf to a 10 uf that one is in the pic. Tried a fixed resistor to.. 10k
damn i suck at this
tracecom
Joined Apr 16, 2010
3,944
Are you using a dual voltage power supply? LM741's need a + supply, a - supply, and a ground. A couple of 9V batteries can be configured to work.
