relationship between poles and zeros of a transfer function and its bode plot
Discussion in 'General Electronics Chat' started by sp2821, Jun 18, 2015.
  1. sp2821
    Jan 8, 2014
    12
    Hi all,
    I am having a hard time grasping concepts of poles/zeros of a transfer function and magnitude bode plot and relationship between them.
    From my understanding, pole and zero are any values of s that makes denominator and numerator = 0, respectively.
    This to me sounds like at zero, H(s) will be 0 and 20*log(0) will be -inf.
    Or at pole, H(s) will be +inf and 20*log(+inf) will be +inf.
    However, for example, if H(s)=K(s+2), the magnitude bode plot is flat from s=0 to s=2 with DC gain of K and have slope of +20dB/dc from s=2 to s=+inf.
    Why is this? Shouldn't it look like a notch filter?
    Thanks,
  2. ramancini8
    Member
    Jul 18, 2012
    447
    119
    First a notch filter requires more than one pole/zero to get up and down movement of the transfer function.
    H(s) = K(s + 2)/(s + 6)(s + 8) yields the upward line until (s + 6) flattens out the curve; then (s+8) causes the curve to head for -infinity. Your poor notch filter.
  3. tindel
    Sep 16, 2012
    576
    196
    Why do you think it should be a notch filter? I'm not following you there. A transfer function with a single zero is a differentiator.
  4. tindel
    Sep 16, 2012
    576
    196
    Actually - I think you mean H(s) = K*s/(s+2)^2 will give you a poor mans notch filter at 2 radians.
    s will be a differentiator out to 'DC' (-inf at s=0) and the first pole will flatten out the curve and the second pole will cause the curve to go downwards to -inf when s=+inf
  5. ramancini8
    Member
    Jul 18, 2012
    447
    119
    Same-same theory just said different.
  6. tindel
    Sep 16, 2012
    576
    196
    Err... yeah we're on the same page, but what you described was a low pass filter with gain in a limited band - technically it did differentiate, but just for a small part of the frequency spectrum creating a small bandpass filter. I described a traditional band-pass filter [not a notch filter... oops].
    A traditional notch filter would take the form H(s)=K*(s+1)^2/((s+0.1)(s+10))
  7. MikeML
    Oct 2, 2009
    5,450
    1,066
    Not quite!
  8. sp2821
    Jan 8, 2014
    12
    Well, my question is why? If H(s)=K(s+2), H(s)=0 only when s=-2. But when
    Mike could you explain why?
    At zero, H(s) has value of 0.
    At pole, H(s) has value of +inf.
    So if you take log of magnitude of H(s), shouldn't 20*log(mag(H(s)) have value of -inf at zero and +inf at pole?
