Relation ships between Nuclear Fuel, Control Rods and other stuff
Discussion in 'Off-Topic' started by Robin Mitchell, Dec 2, 2009.
  1. Robin Mitchell
    Oct 25, 2009
    738
    206
    Hi guys
    At the moment i am making a Nuclear Reactor simulator and i want to come up with some way (or formula) that will determin the temperature of the reactor. The temp. can not exceed 800 C and the following are factors:
    Primary coolant fluid
    Control Rods
    Fuel left
    Emergancy coolant
    Think thats it, any ideas?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    There is likely to be a relationship between neutron flux and the heat developed. The type of reactor and the working fluid have mutual effects as well.
    You could always have fun and model the Russian RBMK type graphite pile reactor. Watch the start-up, though.
  3. mik3
    Feb 4, 2008
    4,846
    63
    As long as you are happy with simulations and are not building a real one is fine. :p
  4. Robin Mitchell
    Oct 25, 2009
    738
    206
    yup, no real ones here :D
    Im just a little annoyed at the sim though, because it has no "randomness" so it is very easy to get a constant temperature and not have spikes or uncertanties
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    So to add to your identification of science,
    If it glows = Nuclear.
  6. Robin Mitchell
    Oct 25, 2009
    738
    206
    Thanks for the indent. scien.
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Watch the very bad movie "China Syndrome". You may not want too much randomness. Also look at the history of the British Windhill reactor, as well as that RBMK at Chernobyl in Russia.
  8. Robin Mitchell
    Oct 25, 2009
    738
    206
    British Windhill reactor? nothing on it in google
  9. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  10. Robin Mitchell
    Oct 25, 2009
    738
    206
    OK, cant find the film China syndrome so im going to get that on amazon. Why did you want me to look at these anyway?
    At the end of the day, all i want is a nice formula or system where the temperature depends on variable, and that the temperature is not 100% predictable
  11. Wendy
    Mar 24, 2008
    20,772
    2,540
    The film was pretty hokey, but it had the fortune to come out around the same time as the Three Mile Island fiasco. Basically it describes a scenario where the core melt out of control, and starts burning a hole to China. Our nuclear disaster was an equipment blip, but the Russians showed us how to really stage a nuclear disaster.
    http://www.angelfire.com/extreme4/kiddofspeed/index.html
  12. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The Brits beat Chernobyl by 40-some years. It (Windscale) was a similar design that burned the graphite core for several days. At least it did not explode.
    The whole point is to illustrate why variability in reactor cores is not a warm and fuzzy idea. Everything needs to be very boringly predictable.
  13. someonesdad
    Jul 7, 2009
    1,585
    141
    For some engineering details and formulas, I'd recommend getting a text on reactor engineering. I have one that was my father-in-law's, as he worked on reactor instrumentation in the 50's: "Principles of Nuclear Reactor Engineering" by Glasstone, VNR, 1955. I've browsed through it and it's an excellent text. I'd imagine one could be found in a used bookstore or web bookseller for a few bucks/quid.
    The randomness you desire probably won't come from the equations used to model things (unless the system's time evolution is chaotic) -- you'll have to add that behavior in empirically.
  14. Wendy
    Mar 24, 2008
    20,772
    2,540
    One of the problems with Three Mile Island (as I recall) is their "sensor" for a valve was a flip flop. Problem was, the valve didn't always toggle properly, so the indicator got out of sync with the actual state of the valve. Someone saved a few buck in other words.
  15. Robin Mitchell
    Oct 25, 2009
    738
    206
    lol, someone saved a few bucks
  16. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If you want to expand your understanding of people and manipulation of data, look at the response to the accident. The actual release of radiation was very small, but the anti-nuclear interests played up the what-might-have-happened aspects until it sounded like the entire East Coast of the U.S. was threatened.
    The plant management, realizing that careers were on the line, refused to take sensible action until things were awfully far along. That did not help the reporting of the accident, which should have been fairly trivial.
    Those old 1950's design boiling water reactors are not very impressive in action, either. No reasonable superheat to the generated steam, so plant efficiency is very low.
