Increasng the sampling rate suggests that you are taking samples more often. That would in turn improve resolution.Hi,
how increase in sampling rate reduces resolution?
Any help would be greatly appreciated and thanks in advance.
you could run into problems if your sampling rate is faster than the controllers ability to handle it. An ADC greater than 8 bits into an 8 bit controller for instance. Another problem could be the need for smoothing algorithms if your sampling a jittery line, resulting in processing overhead. Although sampling speed does not imply resolution as mentioned, in practicallity, it could.Hi,
by Jake Hertz
by Aaron Carman
by Jake Hertz
