regulators
Discussion in 'General Electronics Chat' started by duxbuz, Apr 3, 2014.
  1. duxbuz
    Feb 23, 2014
    133
    hi
    I am after using a 9v battery to power a digital circuit that needs only 5v
    My supplier is out of 9v to 5v regulators
    I had a couple of questions
    1. Can i accomplish the same regulation using resistors and capacitors? Is it better to use a voltage regulator?
    2.It seems that there are lots of 5v regulators but they are minimum 10v. I presume this is no good if I am using a 9v battery, or is it acceptable?
    There seem to be quite a few of these types
    I wonder if this would be ok
    http://cpc.farnell.com/texas-instruments/lm2594n-5-0/switching-reg-0-5a-5-0v-2594-dip8/dp/SC08553
  2. ericgibbs
    Jan 29, 2010
    2,581
    389
    Whats your location.?
    There are lots of regulators that will work with a 9V battery and give 5V output.
    What is the 5V current load.?
    E
  3. duxbuz
    Feb 23, 2014
    133
    To be totally honest, impatient as I am, I have not got really paid lots of attention to the current, I was just buying parts off a crib sheet and was hoping to learn about the current as I got started. My location is UK
    There is a mention in document about the circuit consuming 60mA at 5.0Volt
  4. ericgibbs
    Jan 29, 2010
    2,581
    389
  5. duxbuz
    Feb 23, 2014
    133
    Thanks I will look on here.
    I was reading an article where the chap used a
    LM7805CT
    whilst using 9v dc battery
    Is that ok?
  6. ericgibbs
    Jan 29, 2010
    2,581
    389
    A 7805 will work down to +7.5V input for currents upto ~ 250mA
    Always add a 100nF cap on both the input and output of the 7805.
    duxbuz likes this.
  7. duxbuz
    Feb 23, 2014
    133
    Just wondered why capacitors are needed either side?
  8. MrChips
    Oct 2, 2009
    12,623
    3,451
    How much current does your circuit require?
    If the current requirement is low enough you can use a 78L05 or even a 5.1V zener diode (with a current limiting resistor).
    Note that the LM7805CT while readily available and inexpensive, it is not the only solution.
    Voltage regulators are servo feedback mechanisms. If you get a perturbation it is possible that the regulator could oscillate. Sometimes the datasheets will call for a 1 to 10μF tantalum electrolytic capacitor on the output.
  9. duxbuz
    Feb 23, 2014
    133
    One more great question
    http://www.fairchildsemi.com/ds/LM/LM7805.pdf
    when I look here I see it says input voltage as low as 5v
    Am I reading that correctly?
    Where would I find a datasheet that might state capacitance?
    Just trying to educate myself so I don't have to keep asking the same questions
  10. MrChips
    Oct 2, 2009
    12,623
    3,451
    You are not reading the specs correctly.
    It says typical dropout voltage is 2V. Hence the input voltage > 7V.
  11. Alec_t
    Sep 17, 2013
    5,966
    1,133
    The datasheet you linked to in post #9! See Fig 9, page 19.
    duxbuz likes this.
  12. duxbuz
    Feb 23, 2014
    133
    Ok Thanks
    I have (a little) more understanding about dropout voltage now.
    but....
    I wonder why the datasheet has
    Input Voltage​
    VO = 5 V to 18 V
    mentioned if the output is 5v and the dropout is 2v
    Unless the output can possibly be 3v at anytime
  13. geko
    Sep 18, 2008
    9
    The datasheet is for the LM78XX regulator series.
    It comes in variants with output voltages of 5, 6, 8, 9, 10, 12, 15, 18 and 24 volts
    The data sheets shows the maximum input voltage for regulators with outputs from 5-18 volts is 35 volts, and for the 24 volt type, 40 volts.
    For any of them the dropout voltage is 2 volts, so the input must be at least 2 volts more than the output and never more than the maximum input voltage.
    For the LM7805 that is an input voltage in the range 7-35 volts
    duxbuz likes this.
  14. tracecom
    Apr 16, 2010
    3,878
    1,396
  15. Alec_t
    Sep 17, 2013
    5,966
    1,133
    You can input 5V if you want, but that won't give 5V out.
    Here's a sim of output versus input:
