There is a 10 ohm resistor in series before a regulator
This 10 ohm resistor takes up half of the wattage of the regulator doesn't get to hot?
The resistor is rated at 1 watt
Without the 10 ohm resistor before the regulators input pin, the regulator would have the full wattage and heat across the regulator?
When there is a SHORT on the output of the regulators output pin, the current is increased, why does the 10 ohm resistor open?
When the current increases
