Regulator LM317
Discussion in 'General Electronics Chat' started by finne, Oct 17, 2013.
  1. finne
    Jul 29, 2013
    9
    Sorry for the short title, it was just to get around the title bug i read you're having
    Im making a simple battery charger where the goal is to feed a constant voltage of 4.25 volts to the battery until the charging current reaches 1 mA. That is the battery resistance increases until this current is reached. But how do I measure the charging current? The voltage across the battery is of course kept constant, so I can't just measure that. I'm using a LM317 as a voltage source configured as in the picture. My R2 is fixed to 560 ohms and C2 wasn't needed.
  2. wayneh
    Sep 9, 2010
    12,361
    3,220
    Why 1mA? A constant voltage charger eventually reaches (essentially) zero current when the battery emf equals the set point voltage. Set it and forget it.
    If you must, you could use a current sense shunt resistor in series with the battery, and use a comparator to watch the ∆V across that resistor.
  3. #12
    Nov 30, 2010
    16,655
    7,293
    Connect your milliamp meter in series from the output of the regulator circuit to the positive battery terminal.
  4. finne
    Jul 29, 2013
    9
    Thanks! I don't exactly know why I would stop at 1 mA. It's stated in a charging procedure that I read. I'll try to just leave it for a while and see what happens.
  5. #12
    Nov 30, 2010
    16,655
    7,293
    If you pick the right voltage, you can leave the charger on for years. It's called, "float" charging. My lawn mower has a sealed lead acid battery and an LM317 regulator and it stays plugged in all the time, but it never gets below about 4 ma. Probably because it's a lot bigger than your battery. I once stored a car for a year and that battery floated at about 20 ma. It's about internal leakage and self-discharge. As far as I know, all batteries bigger than coin cells have a little bit of that self-leakage.
  6. wayneh
    Sep 9, 2010
    12,361
    3,220
    That works great for lead acid. You have to pay attention to the temperature since this affects the target voltage setting, but otherwise it's fine.
    I'm pretty sure constant voltage is not as reliable for other chemistries, though.
    #12 likes this.
  7. MaxHeadRoom
    Jul 18, 2013
    10,813
    2,491
  8. bountyhunter
    Sep 7, 2009
    2,498
    507
    That sounds like Li-Ion or some LI chemistry. You need a very accurate chanrge voltage to make sure and not overcharge the.
    Sanyo and Sony wanted 4.200V +/- 0.5% for the chips we were going to make to terminate charge.
    An LM317 is pretty crappy for voltage accuracy and temp drift.
    If it is Li, be careful not to overcharge it.
