I am wanting to try and make my regulator charger a more suitable unit.
The input can go as high as 34 volts and I want a regulated 13.8 Volt 1 Amp output to charge the battery. I have the regulator working ok but want to Add 1 Amp current limiting. Also what I don't understand is if the voltage drops to say 18 Volts will the output on the regulator still be 13.8 Volts?
What Can I do to limit the current to 1Amp. I know the LM317 will cut out if the Amperage exceeds 1.5 Amps. However if the battery is very flat it will try to draw more than 1 Amp.
To protect the battery I would like to add a circuit that will switch out the load at 10.6 volts and only switch it back on when the battery starts to charge again , I have included a fixed 12 Volt 1 Amp output.
Any help will be greatly appreciated.
