Hey guys , I am planning to build a regulated power supply but cannot get my hands on a voltage regulator, but i do have a few npn transistors can i use them like in the image to regulate the voltage?
I will go with this one, very simple thankyou.this is an example of a basic voltage regulator (open loop)
one in earlier link is closed loop and much more stable
OK thanks ,i really appreciate the helpyes, you can, you can put several of them.
but they will not share the load equally (one may supply 80% of current and other 20%). to help balance the loading, one adds small resistors in emitter circuit of each transistor (say 0.1 Ohm for example).
usually power transistor have poor gain (unless you use Darlington) so you may need to add one more transistor to increase gain. this way you are not drawing big current from reference circuit (you don't need large power zener, potentiomer).
Thread starter | Similar threads | Forum | Replies | Date |
Help needed with power supply rectification and regulation! | Power Electronics | 9 | ||
Y | Help for voltage regulation | General Electronics Chat | 7 | |
Y | Help for Power regulation | Power Electronics | 4 | |
S | help understanding power regulation | Power Electronics | 6 | |
LED Array Help (Current regulation) | General Electronics Chat | 13 |
