I have a need to regulate the 124 VAC coming from the outlet in my lab down to 115-120 VAC.
The reason for this is I have 200-240 VAC motor, and motor driver I need to power. I know the best option is to have a 220 leg installed from the electrical panel of the building. That is something we plan to do in the future. Right now the ideal situation is if I can get a balanced 220 VAC, that can handle or supply the inrush when motor is turned on, from a standard 115-125 VAC american wall outlet.
Currently have a step-up transformer that is built for refrigerators, so it can handle the inrush. The problem is the power from the outlet is 124 VAC so the load side of the transformer is 246 VAC. This is above the 240 voltage the manufacture recommends for the motor and driver.
I appreciate any help or suggestion.
