Regulated supplies before semiconductors.
Discussion in 'General Electronics Chat' started by WBahn, Aug 29, 2013.
  1. WBahn
    Thread Starter Moderator
    Mar 31, 2012
    18,089
    4,917
    So I just got to thinking about how one would go about producing a regulated voltage output (say just a linear DC supply) without using a regulator chip and, of course, the first things that come to mind are using zener diodes or some such as a voltage reference. But that got me to wondering how they made well-regulated supplies back in the days before semiconductors. How did you get a decent voltage reference?
    Anyone know?
  2. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    I have a few of the old ones built by GFC Hammond and the one I have in front of me now looks very simple, a MC1723 and a 2N6576 pass transistor.
    I do have some models that also have the Crowbar O.V. shut down.
    Practically all also have output terminals for remote sense regulation.
    If you are going back before semiconductor types then they would most likely had tube regulation and the equivalent to the zener back then was the neon tube and thyratrons, the equivalent to the SCR was Thyratron and the Mercury Ignitron.
    Max.
    WBahn likes this.
  3. WBahn
    Mar 31, 2012
    18,089
    4,917
  4. studiot
    Nov 9, 2007
    5,005
    515
    In those days Mullard was still a manufacturing force to be reckoned with and they produced a book
    Transistorised Power Supplies, attributed to JR Nowicki.
    This has a whole section entitled High-stability reference sources.
    I also remember a large book on the subject, when I was a college, produced by Texas Instruments, though I could never afford a copy.
  5. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    I still have my copy of Radio Valve Data with all the characteristics for Mullard, Brimar, Cossor, Emitron, Ferranti, Marconi etc ..etc.
    I have worked with both Thyratrons and Ignitrons also a neon counting tube called a Dekatron.
    The Ignitron is quite the device, a large steel encased tubular glass chamber that has a main Cathode which has a pool of mercury over it, the phase angle controlled ignitor rests in the pool of mercury and when low current is passed through the mercury pool via the ignitor , it ionizes the gas and conducts to the large anode and switch off as the AC sweeps through the half cycle, for full wave control you need two, back to back.
    Max.
  6. #12
    Nov 30, 2010
    16,705
    7,355
    My mind quickly goes to using a vacuum tube as a constant current source.
    ΔIp/ΔB+ is very small when Vgk is fixed.
  7. studiot
    Nov 9, 2007
    5,005
    515
    Here is an extract from the Mullard Book.
    The give considerable detail of analysis and experimental results as compared to primary sources (Weston Cell)
  8. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    Before semi's.
    Max.
  9. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
  10. studiot
    Nov 9, 2007
    5,005
    515
    The question was
    Not how do you regulate?
    So how decent a reference was V3 and V4?
  11. tracecom
    Apr 16, 2010
    3,879
    1,396
    Wasn't the question regarding regulators before semiconductors, i.e., no transistors and no diodes?
  12. studiot
    Nov 9, 2007
    5,005
    515
    Well perhaps I misunderstood post#1.
    WBahn talked about what would happen without regulator chips.
    But its true the title says before semiconductors, which takes us back a very long way if you take that strictly. In fact I am just trying to fix my microwave which gets its regulation from and incredibly massive transformer. So non semiconductors are still in use.
  13. sheldons
    Oct 26, 2011
    616
    101
    heres my valve portable psu and footwarmer schematic and studiot whats wrong with your mw?
  14. studiot
    Nov 9, 2007
    5,005
    515
    As I said before it's 28 years old and needs a new magnetron. (it overheats and the cutouts shut it down after a couple of minutes of operation). The HV capacitor, fan and diode test out just fine.
    I have looked at new microwaves, but they do not offer the facilities I originally picked this one out for.
  15. #12
    Nov 30, 2010
    16,705
    7,355
    What? Using microprocessors doesn't do what you want? How could that happen?:rolleyes:
    ps, there's a person (just al) in Electronics Resources forum right now with the same overheat problem.
  16. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    Neon regulators were pretty good IIR, the output was considered at the time to be 'Fairly Reasonable' ?
    I don't have numbers, unfortunately.
    The method used is also an old one, part saturation by magnetic shunt.
    Max.
