regulated power supply
darkknight
Joined Oct 7, 2009
41
hi,
I have to build a regulated power however i am quite confused with the specs requisition and was hoping that someone could help me. these are the specs
D.C. Output is 10 V
Load Variation is 300 – 9000ohms
Ripple Factor has to be Less than 0.1% for 1900ohms load
Load Regulation has to be better than 4 mV for a 1 mA change in load current
Line Regulation has to be better than 4 mV for a 1V change in line voltage
i am stuck on the regulation portion of it, how would i calculate the rs and rl?
thanks in advance
darkknight
Joined Oct 7, 2009
41
dont i need an rs to drop the extra voltage from the zener diode? i have trouble "translating those specs to their terms such as rl, so i guess the rl is the load variation where i can pick from 300 to 9000?
#12
Joined Nov 30, 2010
18,224
Why not just pick the right voltage zener diode?
You pick all the values from 300 ohms to 9000 ohms. The circuit has to work at both of those loads and everywhere in between.
#12
Joined Nov 30, 2010
18,224
If you want 10 volts, choose a 10 volt zener diode.
Why would you choose an 11 volt zener diode and then add a resistor?
The Rl is given as 300 ohms to 9000 ohms.
Those are the answers to the questions you asked.
Now it is time for you to post your effort to design the circuit, or do calculations, or something.
This is the Homework forum. It is YOUR homework.
Do something besides repeating the same question.
WBahn
Joined Mar 31, 2012
30,045
hi,
D.C. Output is 10 V
thanks in advance
If you have an ideal voltage supply, does the load voltage change if the load current changes?
If you have a real voltage supply, does the load voltage change if the load current changes?
If you have a real voltage supply, how much does the load voltage change by as a result of a change in the load current?
What parameter describes this relationship?
anhnha
Joined Apr 19, 2012
905
May I try to answer these questions? I still don't understand all the specs above.
No, it doesn't.
Yes, it does.
Let's call the internal resistance of voltage supply, load resistance are Rs and RL respectively. Vs is the voltage of ideal voltage supply and IL is the current flowing through the load.
\(V_{ R_{L} } = V_{s} - I_{L}. R_{s} \)
\( \Delta V_{ R_{L} } = - \Delta I_{L}. R_{s} \)
Load Regulation has to be better than 4 mV for a 1 mA change in load current.
This means that with 1 mA change in load current, the voltage across the load has to be less than 4 mV, right?
\( \Delta V_{ R_{L} } \leq 4mV \)
\( \Delta I_{L} = 1mA\)
From this we have constrain for the internal resistance:
\(R_{s} \leq \frac{ \Delta V_{ R_{L}}}{ \Delta I_{L}} = \frac{4mV}{1mA} = 4 \Omega \)
Here is my understanding about other parameters.
D.C. Output is 10 V
Not sure how to use the load variation spec.
From load range, I calculated current range: 10V/9000Ω to 10V/300Ω
The maximum current is 1/30A => Rs < 30S*Vs = 300Ω
Is that correct?
And what does this spec mean?
Jony130
Joined Feb 17, 2009
5,488
Your answer looks good. Except I don't understand what are you doing here
As for Line Regulation - if voltage at regulator input change be 1V. The regulator output voltage cannot change more then 4mV.
Jony130
Joined Feb 17, 2009
5,488
anhnha
Joined Apr 19, 2012
905
Well, I didn't know that we have to use the regulator with Zener diode like that.
I got stuck with that circuit. How can I use this information.
Jony130
Joined Feb 17, 2009
5,488
But for any voltage regulator circuit we can find Line Regulation and Load Regulation
"Load Regulation has to be better than 4 mV for a 1 mA change in load current"
But you already did that correctly. Then for a given voltage regulator, you need to find Rout and and ensure that Rout < 4mV/1mA = 4Ω
WBahn
Joined Mar 31, 2012
30,045
In general, it would be better if you held off and gave the OP a chance to see them and ponder them and attempt to answer them. After all, this is THEIR thread and the primary purpose should be to maximize the help to THEM. The point of the questions is to get them to THINK about the concepts and draw upon THEIR understanding of the material to form conclusions. That process is largely (but not totally) defeated if someone else does the thinking for them.
If they don't answer after a few days, then it becomes fair game.
anhnha
Joined Apr 19, 2012
905
Sorry about that. :(
I shouldn't have hijacked someone else's thread.
WBahn
Joined Mar 31, 2012
30,045
At least not without giving them the chance. But don't fret too much over it. It's a real easy thing to do (and pretty much all of us have done it). The more we are aware of it, the less we (hopefully) do it. And some good discussion took place which will hopefully help the OP (if they ever come back).
